1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Options for reviving old Allen Bradley PLC implementations
Date: Tue, 9 Nov 2010 09:15:10 +1100
Another  option could be to use Prosoft modbus module “MVI46-MNET” and the rich EPICS modbus support from Mark Rivers and others.
One issue I have found with Prosoft modules is that as it is a completely standalone processor it is possible that the PLC could be stopped and the Prosoft module will continue to communicate stale values up to the IOC. I would be implementing heartbeats (in both directions) in the PLC logic.
Bryce Karnaghan
From: [email protected] [mailto:[email protected]] On Behalf Of Chestnut, Ronald P.
Sent: Saturday, 6 November 2010 6:31 AM
To: [email protected]
Subject: Options for reviving old Allen Bradley PLC implementations
We have a number of old Allen Bradley PLC implementations here at SLAC. One of these uses a Data Communication Card (DCM) in VME is connected to the SLC5 SLC500s. One path we are considering is using an RSLogix PLC (which has good EPICS support) as the master PLC, and slaving the SLC5 PLC to that. It turns out that there exists a package to translate the ladder logic from SLC500 to RSLogix.
Another group here is asking the following:
“We have some old SLC 5/04 PLCs from Allen Bradley that we wanted to make EPICS compatible. I found a third party SLC module that talks Ether/IP:
Will this module work to provide the EPICS support? “
Another piece of information is from Ernest Williams: He warned us against the direct SLC-50x EPICS driver support, since it uses its own protocol (DFI?) and has a poor reputation and poor support.
So the questions to the community are
How are you reviving old PLC support? What has or has not worked? What do you recommend?
Ron Chestnut
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Options for reviving old Allen Bradley PLC implementations Chestnut, Ronald P.
Prev: RE: EPICS integration of streak camera, fast-gated camera Mark Rivers
Next: Re: Some Channel Access Questions Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Options for reviving old Allen Bradley PLC implementations Maren Purves
Next: build streamDevice 2-4 error Ding Jianguo
ANJ, 08 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
