1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: build streamDevice 2-4 error
To: <[email protected]>
Date: Sun, 7 Nov 2010 22:55:16 +0800
hi, all,
I re-built an IOC  with ScientificLinux 5.5, base-3-14-11, asynDriver 4-12, and streamDevice2.4.
Linux, base, and asynDriver were installed OK. Following errors occured when I compiled streamDevice2-4.
Does anyone give us instructions?
Thanks in advance.
Jianguo Ding
SSRF Control group
[root@localhost StreamDevice-2-4]# make
make -C ./src install
make[1]: Entering directory `/root/apps/StreamDevice-2-4/src'
perl /usr/local/epics/base/base-3-14-11/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[2]: Entering directory `/root/apps/StreamDevice-2-4/src/O.linux-x86'
Installing created dbd file ../../../dbd/stream.dbd
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux -I/usr/local/epics/base/base-3-14-11/include  -I/usr/local/epics/support/asyn-4.12/include            ../AsynDriverInterface.cc
../AsynDriverInterface.cc: In member function ‘void AsynDriverInterface::writeHandler()’:
../AsynDriverInterface.cc:630: warning: enumeration value ‘asynDisconnected’ not handled in switch
../AsynDriverInterface.cc:630: warning: enumeration value ‘asynDisabled’ not handled in switch
../AsynDriverInterface.cc: In member function ‘void AsynDriverInterface::readHandler()’:
../AsynDriverInterface.cc:810: warning: enumeration value ‘asynDisconnected’ not handled in switch
../AsynDriverInterface.cc:810: warning: enumeration value ‘asynDisabled’ not handled in switch
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux -I/usr/local/epics/base/base-3-14-11/include  -I/usr/local/epics/support/asyn-4.12/include            ../EnumConverter.cc
/usr/bin/gcc -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/base-3-14-11/include/os/Linux -I/usr/local/epics/base/base-3-14-11/include  -I/usr/local/epics/support/asyn-4.12/include            ../devwaveformStream.c
../devwaveformStream.c: In function ‘readData’:
../devwaveformStream.c:52: warning: implicit declaration of function ‘errlogSevPrintf’
../devwaveformStream.c:52: error: ‘errlogFatal’ undeclared (first use in this function)
../devwaveformStream.c:52: error: (Each undeclared identifier is reported only once
../devwaveformStream.c:52: error: for each function it appears in.)
../devwaveformStream.c:132: error: ‘errlogMajor’ undeclared (first use in this function)
../devwaveformStream.c: In function ‘writeData’:
../devwaveformStream.c:184: error: ‘errlogFatal’ undeclared (first use in this function)
make[2]: *** [devwaveformStream.o] Error 1
make[2]: Leaving directory `/root/apps/StreamDevice-2-4/src/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/root/apps/StreamDevice-2-4/src'
make: *** [src.install] Error 2
Re: build streamDevice 2-4 error Rod Nussbaumer
Prev: Re: monitors received out of order Kate Feng
Next: Modbus R2-1 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Options for reviving old Allen Bradley PLC implementations Bryce Karnaghan
Next: Re: build streamDevice 2-4 error Rod Nussbaumer
ANJ, 08 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
