1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus R2-1 available
To: <[email protected]>
Date: Sun, 7 Nov 2010 11:51:48 -0600
Release 2-1 of the EPICS "modbus" module is now available.  This is from
the release notes:
- Bug fix. Non-automatic connection to the Modbus server uses
pasynCommonSyncIO->connectDevice(). The pasynUser being used for that
operation was being created with pasynOctetSyncIO->connect(). That was
always an error, it must be created with pasynCommonSyncIO->connect().
This error became serious with asyn R4-14, and non-automatic connection
no longer worked.
- Previous releases of modbus recommended setting NoAutoConnect=1 when
configuring the TCP or serial port. That was probably because of
problems in connection management in earlier versions of asyn. With asyn
R4-14 this is no longer necessary, and NoAutoConnect=0, the normal
default, can be used with no problems. The example scripts Koyo1.cmd and
Koyo2.cmd in the iocBoot directory have been changed to enable automatic
connection to the IP or serial driver.
Thanks to Zen Szalata of SLAC for finding this bug.
The release notes are here:
http://cars.uchicago.edu/software/epics/modbusReleaseNotes.html
The documentation is here:
http://cars.uchicago.edu/software/epics/modbusDoc.html
The tar file is here:
http://cars.uchicago.edu/software/pub/modbusR2-1.tgz
Please let me know of any problems or questions.
Cheers,
Prev: build streamDevice 2-4 error Ding Jianguo
Next: mca R6-12-2 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: build streamDevice 2-4 error Rod Nussbaumer
ANJ, 07 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
