1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Some Channel Access Questions
To: [email protected]
Date: Tue, 9 Nov 2010 00:46:57 +0100
On Mittwoch, 27. Oktober 2010, Tim Mooney wrote:
> One point that is probably obvious to you guys, but was obvious to me
> only in retrospect,
> is that it matters *where* in the processing chain the asynchronous
> record occurs.
> If the only asynchronous record in the chain is the first one, you
> can get good behavior
> from a sequence of ca_put_callbacks and be fooled into thinking that
> server-side code
> is more aware of putNotify than it actually is.  This is because the
> first record's PACT field
> will be True all the while the putNotify is active, so server-side
> code, which only honors
> record locks and PACT fields, will accidentally be honoring putNotify
> as well.
> To make a good ca_put_callback test, you have to write to a
> synchronous record that links
> to an asynchronous record.  In this case, when the first record has
> written to the asynchronous
> record, and that record has gone into its asynchronous wait, both the
> lockset and the
> first record's PACT field will look ready for another
> ca_put_callback, but the putNotify
> fields will not be ready, and you'll be able to see the problem you
> need to defend against.
I made such a test, using a bo record that writes to a seq with a delay
of 2 seconds, which in turn writes to yet another bo. The test uses
several ca_put_callback requests to the (first) bo record in a row with
a small delay (0.2 seconds) in between. I make sure that CA client
buffer is flushed after each call.
The results clearly show that ca_put_callback requests are queued in the
server, even though the targeted bo record is certainly *not*
asynchronous (DTYP=Soft Channel), although the next record in the
processing chain --the seq record-- is (because of the delay). I
receive the callbacks, one after the other, with the same delay in
between as I have configured in the seq record; this is long after all
the ca_put_callback requests have been sent. I do not get a bad status
from the callbacks.
I am very glad I got these results, because this is how it should be! It
means I can treat pvPut/ASYNC in the sequencer in the same way as
pvGet/ASYNC, i.e. requests and callbacks can overlap.
(Note, however, that this result is with multiple ca_put_callbacks from
the same client and to the same PV. I have not yet tested what happens
if I target different fields of the same record.)
Cheers
Ben
Some Channel Access Questions Ben Franksen
RE: Some Channel Access Questions Jeff Hill
Re: Some Channel Access Questions Tim Mooney
Prev: RE: Options for reviving old Allen Bradley PLC implementations Bryce Karnaghan
Next: Re: base 3-14-11 and breakpoint tables for ai and ao Mark Clift
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Some Channel Access Questions Ben Franksen
Next: OMS MAXv announces fix Ron Sluiter
ANJ, 09 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
