1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: whether PPC604 in vxWorks5.5.1 include PowerPC 750GX
To: [email protected]
Date: Mon, 8 Nov 2010 11:07:34 -0500
On Monday 08 November 2010 03:44:54 çæ wrote:
> My confusion is that, in document "VxWorks5.5 for PowerPC
> Architecture Supplement",it shows as follows, which says PowerPC 750GX does
> not belong to PPC604.
I suspect that document may have been created before the 750GX was released;
it doesn't say that the 750GX CPU does not belong to the PPC604 family, it
doesn't list it at all which is not quite the same thing.
> While in document "vxworks architecture supplement 6.7", it shows as
> follows, which says PowerPC 750GX belongs to PPC604.
Since the second document does explicitly say that the 750GX does belong to
the PPC604 family I would believe that.  The PPC604 classification indicates
the instruction set that the CPU executes, and it can't change with different
operating system versions.
> So, I am not sure if PPC604 in vxWorks5.5 includes PowerPC 750GX. Isn't the
> "PPC604" in vxWorks5.5 and vxWorks6.7 the same? In my EPICS environment,
> can I choose CPCI6190 board?
The fact that the 750GX is a PPC604 doesn't mean that it will _definitely_
work with vxWorks 5.5, but I suspect it probably will.  There are various
reasons that it might not relating to things like any additional registers it
may have that have to be configured, and vxWorks might check the processor ID
register.
I don't know anything about the CPCI6190, but you should ask the board vendor
whether they can provide a vxWorks 5.5 BSP for it.  If they do then that
answers your question and I could see no reason why you wouldn't be able to
run EPICS on it.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
whether PPC604 in vxWorks5.5.1 include PowerPC 750GX 王林
Prev: whether PPC604 in vxWorks5.5.1 include PowerPC 750GX 王林
Next: EPICS Suggestions and Priorities Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: whether PPC604 in vxWorks5.5.1 include PowerPC 750GX Ralph Lange
ANJ, 18 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
