On 11/2/2010 10:17 AM, Ernest L. Williams Jr. wrote:Sorry, for my late reply as I did not have a Solaris machine. The same problem indeed happens on Solaris as confirmed by Stephanie Allison. Here is epicsThreadShowAll on solaris 10: flora02:iocBoot/ioctestStatsSoft>../../bin/solaris-sparc-gnu/testIocStats
epics> < st.cmd
#!../../bin/linux-x86/testIocStats
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","ioctestStatsSoft")
epicsEnvSet("TOP","/afs/slac.stanford.edu/u/qb/saa/spear/iocStats")
epicsEnvSet("EPICS_SITE_TOP","/afs/slac/g/spear/epics")
epicsEnvSet("EPICS_MODULES","/afs/slac/g/spear/epics/modules")
epicsEnvSet("SNCSEQ","/afs/slac/g/spear/epics/modules/seq/seq-R2-0-12-spear1")
epicsEnvSet("EPICS_BASE","/afs/slac/g/spear/epics/base/")
cd /afs/slac.stanford.edu/u/qb/saa/spear/iocStats
# do OS-specific startup here
epicsEnvSet("ENGINEER","engineer")
epicsEnvSet("LOCATION","location")
# Soft IOCs only
epicsEnvSet("STARTUP","/afs/slac.stanford.edu/u/qb/saa/spear/iocStats")
epicsEnvSet("ST_CMD","st.cmd")
dbLoadDatabase("dbd/testIocStats.dbd",0,0)
testIocStats_registerRecordDeviceDriver(pdbbase)
## Load all record instances (VxWorks)
#dbLoadRecords("db/iocAdminVxWorks.db","IOC=IOCTEST")
## or load only those records for RTEMS IOCs
#dbLoadRecords("db/iocAdminRTEMS.db","IOC=IOCTEST")
## or load only those records for Soft IOCs
dbLoadRecords("db/iocAdminSoft.db","IOC=IOCTEST")
## optionally load the SCAN monitoring records
dbLoadRecords("db/iocAdminScanMon.db","IOC=IOCTEST")
dbLoadRecords("db/testIocAdminRelease.db","IOC=IOCTEST")
iocInit()
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Aug 31 2010
#seq(&testSuspension)
#seq(&testCpuUse)
epics> epicsThreadShowAll
NAME EPICS ID PTHREAD ID OSIPRI OSSPRI STATE
_main_ 23fd8 0 0 0 OK
errlog 2b470 2 10 0 OK
taskwd 3e138 3 10 0 OK
timerQueue 337a8 4 70 0 OK
cbLow 30630 5 59 0 OK
cbMedium 80828 6 64 0 OK
cbHigh 808f8 7 71 0 OK
dbCaLink 30770 8 50 0 OK
timerQueue 30bf8 9 60 0 OK
scanOnce 975d8 10 70 0 OK
scan10 97f20 11 60 0 OK
scan5 97fb8 12 61 0 OK
scan2 98050 13 62 0 OK
scan1 980e8 14 63 0 OK
scan0.5 98180 15 64 0 OK
scan0.2 98218 16 65 0 OK
scan0.1 982b0 17 66 0 OK
CAS-TCP 9be98 18 18 0 OK
CAS-beacon 9bf68 19 17 0 OK
CAS-UDP 9c038 20 16 0 OKepicsThreadShowAll() will clearly show this. On the other hand Windows does map the thread priorities as a normal user. :)
I have code that misbehaves when this happens, so I started digging around
| ANJ, 10 Nov 2010 |
Home
News
About
Talk
Base
Modules
Extensions
