On Mittwoch, 10. November 2010, Ben Franksen wrote:
> On Mittwoch, 10. November 2010, Andrew Johnson wrote:
> "Keep the existing simple .db file syntax": I'd like to say: yes, in
> principle, but I am not opposed to (would in fact appreciate) well
> thought-out extensions. So, do I say yes or no?
There is another proposal about moving autosave into base and allowing
to configure array values before iocInit. I think these should be
separate proposals. Concerning the latter, I am strongly for adding
some sort of array syntax to db files, so that array fields can be
configured in db files. This is overdue, and should be easy to design
and implement.
Concerning autosave, if it gets moved into base maybe it make sense to
changed it to use db file syntax.
Cheers
Ben
- Re: EPICS Suggestions and Priorities J. Lewis Muir
- Re: EPICS Suggestions and Priorities Andrew Johnson
- EPICS Suggestions and Priorities Andrew Johnson
- Re: EPICS Suggestions and Priorities Ben Franksen
<2010>
2025
2026
<2010>
2025
2026
