1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stand-alone sequencer programs
To: [email protected]
Cc: Ben Franksen <[email protected]>
Date: Mon, 15 Nov 2010 14:50:43 -0500
On Monday 15 November 2010 13:22:39 Ben Franksen wrote:
> On Montag, 15. November 2010, Ben Franksen wrote:
> > On Montag, 15. November 2010, Andrew Johnson wrote:
> > > While you're making sequencer changes, [...]
> ...would anyone be sad if I removed the -s switch for stand-alone
> sequencer programs (i.e. those which which have been compiled
> with 'snc -m' and thus contain a main function) and instead always
> start them with an iocsh?
> The problem is that it is easy to forget the -s switch which leaves you
> with a program that cannot be interrupted other than with a kill -9
> (SIG_TERM). This is just annoying and I don't see a compelling use
> case.
> A compromise would be to just reverse the default, so you'd need an
> extra switch to say 'no ioc shell'.
That's what I did with the softIoc binary in Base; it used to need a -s option
to enable the IOC shell, now it needs a -S switch to disable the IOC shell
instead. A -s is still accepted, but does nothing.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: Stand-alone sequencer programs Ben Franksen
Prev: Stand-alone sequencer programs Ben Franksen
Next: Re: Stand-alone sequencer programs Ben Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
