On Montag, 15. November 2010, Andrew Johnson wrote:
> On Monday 15 November 2010 13:22:39 Ben Franksen wrote:
> > > > While you're making sequencer changes, [...]
> > ...would anyone be sad if I removed the -s switch for stand-alone
> > sequencer programs (i.e. those which which have been compiled
> > with 'snc -m' and thus contain a main function) and instead always
> > start them with an iocsh?
> > The problem is that it is easy to forget the -s switch which leaves
> > you with a program that cannot be interrupted other than with a
> > kill -9 (SIG_TERM). This is just annoying and I don't see a
> > compelling use case.
> > A compromise would be to just reverse the default, so you'd need an
> > extra switch to say 'no ioc shell'.
> That's what I did with the softIoc binary in Base; it used to need a
> -s option to enable the IOC shell, now it needs a -S switch to
> disable the IOC shell instead. A -s is still accepted, but does
> nothing.
Cool, so I'll copy this behaviour for the sequencer.
Thanks
Ben
"Never confuse what is natural with what is habitual."
-- attributed to Mahatma Gandhi
- Stand-alone sequencer programs Ben Franksen
- Re: Stand-alone sequencer programs Andrew Johnson
Re: Last chance to save the sequencer's pv layer Ben Franksen
<2010>
2025
2026
EPICS Base R3.14.12-rc1 now available Andrew Johnson
<2010>
2025
2026
