1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross-compilation missing library
Cc: [email protected]
Date: Tue, 16 Nov 2010 14:04:48 -0800
Ok, Andrew, I will try your solution.
Now assuming that I need flex... how would I do that?
On 15:30 Tue 16 Nov     , Andrew Johnson wrote:
> Hi Emmanuel,
> On Tuesday 16 November 2010 14:21:36 [email protected] wrote:
> > I am trying to compile the sequencer on arm.
> > I am using a cross toolchain.
> > I am apparently missing the flex library for the arm toolchain.
> You don't actually need it, someone added libfl as a dependent library
> incorrectly (or maybe it was added a very long time ago before we included a
> copy of flex in Base).
> > Is there a way to install the flex library for arm on my linux 64b?
> Edit src/snc/Makefile and delete all of the SYS_PROD_LIBS_* lines from it.
> You may also have to change the line
>     PROD_LIBS += $(EPICS_BASE_IOC_LIBS)
> into
>     PROD_LIBS += $(EPICS_BASE_HOST_LIBS)
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Emmanuel
Re: Cross-compilation missing library Andrew Johnson
Cross-compilation missing library emmanuel_mayssat
Prev: Re: Cross-compilation missing library Andrew Johnson
Next: Re: Cross-compilation missing library Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
