1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to shutdown/restart a soft-ioc from a (watchdog) record
To: [email protected]
Date: Thu, 18 Nov 2010 11:58:04 -0500
On Thursday 18 November 2010 08:32:00 Burkhard Kolb wrote:
> Hi Ralph,
> yes, I tried that. It exits only the thread. Same happens also when I try
> "exit" on the iocsh. If I do a ^X in procServ, it kills it immediately -
> fine. But I wanted to automate this.
Instead of doing the signal thing you should probably call _exit():
       The  function _exit() terminates the calling process "immediately". Any
       open file descriptors belonging to the process are closed; any children
       of the process are inherited by process 1, init, and the processâs par-
       ent is sent a SIGCHLD signal.
       The function _exit() is like exit(), but does not  call  any  functions
       registered with atexit() or on_exit().  ...
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
Re: How to shutdown/restart a soft-ioc from a (watchdog) record Ralph Lange
Re: How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
Prev: Re: MCA (Matlab Channel Access) new version Andrew Johnson
Next: RE: How to shutdown/restart a soft-ioc from a (watchdog) record Al Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
ANJ, 18 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
