> > We agree that epics itself should be build with arm arch to build arm iocs.
> > So I need to have the epics arm libs on my system before compiling the
> > iocs. Well, for epics that's easy since we build from source and epics has
> > only 'standard_c_lib' dependencies. Now what about non-standard libs (like
> > flex ;), which I could yum/apt-get. Do I need to compile them from source
> > against the crosstool? And what about the dependencies of the dependencies
> You're outside my range of expertise there. If you're using a Debian-derived
> Linux and tool-chain or similar that provides those libs pre-built for ARM
> then you should be able to fetch and install them using the standard tools,
> but that's outside the realm of the EPICS developers.
It turns out qemu-arm is used just for that.
Bing or google it and you will see how to build an arm virtual machine (in user space) on
an intel cpu. FYI.
Emmanuel
- Cross-compilation missing library emmanuel_mayssat
- Re: Cross-compilation missing library Andrew Johnson
- Re: Cross-compilation missing library emmanuel_mayssat
ChannelFinder Web Service 1.0.0 (beta) released Ralph Lange
ca_put_callback once again Ben Franksen
<2010>
2025
2026
How to shutdown/restart a soft-ioc from a (watchdog) record Burkhard Kolb
<2010>
2025
2026
