1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subrecord INPx
To: Hinko Kocevar <[email protected]>
Date: Wed, 24 Nov 2010 10:16:44 -0800
Are you sure that your EPICS base and test application are built properly?
I started with the example app and then added code as you showed:
wenorum@enorum 274> cat exampleApp/Db/dbSubExample.db
record(sub,"$(user):subExample")
    field(INAM,"mySubInit")
    field(SNAM,"mySubProcess")
    field(INPA, "$(user):subInc")
    field(INPB, "123")
record(aSub,"$(user):aSubExample")
    field(INAM,"myAsubInit")
    field(SNAM,"myAsubProcess")
    field(FTA,"DOUBLE")
    field(NOA,"10")
    field(INPA,"$(user):compressExample CPP")
record(calc, "$(user):subInc") {
    field(SCAN, "1 second")
    field(VAL, "0")
    field(CALC, "(A+1)")
    field(INPA, "$(user):subInc.VAL NPP")
    field(FLNK, "$(user):subExample")
wenorum@enorum 275> cat exampleApp/src/dbSubExample.c
static long mySubInit(subRecord *precord)
    if (mySubDebug)
        printf("Record %s called mySubInit(%p)\n",
               precord->name, (void*) precord);
    return 0;
static long mySubProcess(subRecord *precord)
    if (mySubDebug)
        printf("Record %s called mySubProcess(%p)\n",
    printf("precord->a %lf\n", precord->a);
    printf("precord->b %lf\n", precord->b);
    return 0;
When I run this I see:
epics> precord->a 1.000000
precord->b 123.000000
precord->a 2.000000
precord->a 3.000000
precord->a 4.000000
Looks right to me.
On Nov 24, 2010, at 6:49 AM, Hinko Kocevar wrote:
> Hi,
> I'm poking around the example IOC I've created with:
> $ makeBaseApp.pl -t example app1
> $ makeBaseApp.pl -i -t example app1
> Example runs fine and records are behaving as expected, but..
> I tried to experiment with subRecord, but the mySubProcess routine does not seem to get values on INPx fields if they are not constants. I've added following line to get INPA value inside the C function:
>    if (mySubDebug)
>    return 0;
> Example:
>    field(INPB, "123")
>  field(VAL, "0")
> Output from IOC:
> Record hinkoHost:subcall called mySubProcess(0x9205998)
> precord->a 0.000000
> precord->a 0.000000
> precord->a 0.000000
> At the same time, if I monitor the $(user):subInc:
> camonitor hinkoHost:subInc
> hinkoHost:subInc               2010-11-24 15:45:57.346136 14
> hinkoHost:subInc               2010-11-24 15:45:58.346438 15
> hinkoHost:subInc               2010-11-24 15:45:59.346628 16
> What am I missing?
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
Eric Norum
[email protected]
RE: subrecord INPx Hinko Kocevar
Prev: Re: ca_put_callback once again Andrew Johnson
Next: RE: subrecord INPx Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: subrecord INPx Hinko Kocevar
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
