1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: subrecord INPx
To: EPICS Tech Talk <[email protected]>
Date: Wed, 24 Nov 2010 15:49:36 +0100
I'm poking around the example IOC I've created with:
$ makeBaseApp.pl -t example app1
$ makeBaseApp.pl -i -t example app1
Example runs fine and records are behaving as expected, but..
I tried to experiment with subRecord, but the mySubProcess routine does not seem to get values on INPx fields if they are not constants. I've added following line to get INPA value inside the C function:
static long mySubProcess(subRecord *precord)
    if (mySubDebug)
        printf("Record %s called mySubProcess(%p)\n",
               precord->name, (void*) precord);
    printf("precord->a %lf\n", precord->a);
    printf("precord->b %lf\n", precord->b);
    return 0;
Example:
record(sub,"$(user):subExample")
    field(INAM,"mySubInit")
    field(SNAM,"mySubProcess")
    field(INPA, "$(user):subInc")
    field(INPB, "123")
record(calc, "$(user):subInc") {
  field(SCAN, "1 second")
  field(VAL, "0")
  field(CALC, "(A+1)")
  field(INPA, "$(user):subInc.VAL NPP")
Output from IOC:
Record hinkoHost:subcall called mySubProcess(0x9205998)
precord->a 0.000000
precord->b 123.000000
precord->a 0.000000
precord->a 0.000000
At the same time, if I monitor the $(user):subInc: camonitor hinkoHost:subInc hinkoHost:subInc 2010-11-24 15:45:57.346136 14 hinkoHost:subInc 2010-11-24 15:45:58.346438 15 hinkoHost:subInc 2010-11-24 15:45:59.346628 16
What am I missing?
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
Re: subrecord INPx Matthieu Bec
RE: subrecord INPx Allison, Stephanie
Re: subrecord INPx Eric Norum
Prev: Re: sncseq compiling error Benjamin Franksen
Next: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: subrecord INPx Matthieu Bec
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
