Please provide a full (level 5) dbpr output of both records. Also, please provide the version of epics base and the OS of the IOC.
Thank you,
Stephanie
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Hinko Kocevar
> Sent: Wednesday, November 24, 2010 6:50 AM
> To: EPICS Tech Talk
> Subject: subrecord INPx
> Hi,
> I'm poking around the example IOC I've created with:
> $ makeBaseApp.pl -t example app1
> $ makeBaseApp.pl -i -t example app1
> Example runs fine and records are behaving as expected, but..
> I tried to experiment with subRecord, but the mySubProcess routine does
> not seem to get values on INPx fields if they are not constants. I've
> added following line to get INPA value inside the C function:
> static long mySubProcess(subRecord *precord)
> if (mySubDebug)
> printf("Record %s called mySubProcess(%p)\n",
> precord->name, (void*) precord);
> printf("precord->a %lf\n", precord->a);
> printf("precord->b %lf\n", precord->b);
> return 0;
> Example:
> record(sub,"$(user):subExample")
> field(INAM,"mySubInit")
> field(SNAM,"mySubProcess")
> field(INPA, "$(user):subInc")
> field(INPB, "123")
> record(calc, "$(user):subInc") {
> field(SCAN, "1 second")
> field(VAL, "0")
> field(CALC, "(A+1)")
> field(INPA, "$(user):subInc.VAL NPP")
> Output from IOC:
> Record hinkoHost:subcall called mySubProcess(0x9205998)
> precord->a 0.000000
> precord->b 123.000000
> precord->a 0.000000
> precord->a 0.000000
> At the same time, if I monitor the $(user):subInc:
> camonitor hinkoHost:subInc
> hinkoHost:subInc 2010-11-24 15:45:57.346136 14
> hinkoHost:subInc 2010-11-24 15:45:58.346438 15
> hinkoHost:subInc 2010-11-24 15:45:59.346628 16
> What am I missing?
> Best regards,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies d.d.
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review, retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
- RE: subrecord INPx Hinko Kocevar
- subrecord INPx Hinko Kocevar
RE: ca_put_callback once again Jeff Hill
Re: MAXv issue Jens . Eden
<2010>
2025
2026
<2010>
2025
2026
