Title: RE: subrecord INPx
Hi Matthieu,
I stand corrected. It was copy-paste with few manual modifications that resulted in a mistake.
Nevertheless the INPA is not being incremented when calc record increments its VAL, even with FLNK added.
Thank you!
Best Regards,
Hinko
-----Original Message-----
Sent: Wed 11/24/2010 5:33 PM
To: [email protected]
Subject: Re: subrecord INPx
Hi Hinko,
its' not clear in your example how you produced a console trace for your
sub record, there is nothing obvious in your db example to make it process.
try add a FLNK, should work
> record(calc, "$(user):subInc") {
> field(SCAN, "1 second")
> field(VAL, "0")
> field(CALC, "(A+1)")
> field(INPA, "$(user):subInc.VAL NPP")
field(FLNK, "$(user):subExample")
Matthieu
On 11/24/10 11:49, Hinko Kocevar wrote:
> Hi,
> I'm poking around the example IOC I've created with:
> $ makeBaseApp.pl -t example app1
> $ makeBaseApp.pl -i -t example app1
> Example runs fine and records are behaving as expected, but..
> I tried to experiment with subRecord, but the mySubProcess routine does
> not seem to get values on INPx fields if they are not constants. I've
> added following line to get INPA value inside the C function:
> static long mySubProcess(subRecord *precord)
> if (mySubDebug)
> printf("Record %s called mySubProcess(%p)\n",
> precord->name, (void*) precord);
> printf("precord->a %lf\n", precord->a);
> printf("precord->b %lf\n", precord->b);
> return 0;
> Example:
> record(sub,"$(user):subExample")
> field(INAM,"mySubInit")
> field(SNAM,"mySubProcess")
> field(INPA, "$(user):subInc")
> field(INPB, "123")
> field(VAL, "0")
> Output from IOC:
> Record hinkoHost:subcall called mySubProcess(0x9205998)
> precord->a 0.000000
> precord->b 123.000000
> precord->a 0.000000
> precord->a 0.000000
> At the same time, if I monitor the $(user):subInc:
> camonitor hinkoHost:subInc
> hinkoHost:subInc 2010-11-24 15:45:57.346136 14
> hinkoHost:subInc 2010-11-24 15:45:58.346438 15
> hinkoHost:subInc 2010-11-24 15:45:59.346628 16
> What am I missing?
> Best regards,
> Hinko
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- subrecord INPx Hinko Kocevar
- Re: subrecord INPx Matthieu Bec
Re: MAXv issue Jens . Eden
RE: subrecord INPx Hinko Kocevar
<2010>
2025
2026
RE: subrecord INPx Allison, Stephanie
<2010>
2025
2026
