1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MAXv issue
To: [email protected]
Cc: [email protected]
Date: Wed, 24 Nov 2010 17:50:23 +0100
Dirk,
we had this problem at least twice. In both cases we found the fault in
the motor hardware.
Try to measure the resistance of all motor coils and make sure all are
about the same.
HTH
Jens
Dirk Zimoch wrote:
> Hi MAXv users,
> We see a problem here with our MAXv cards and I want to ask if anyone
> has seen the same effect. This could help us to understand what's
happening.
> During a long series of scans that drives a motors in negative direction
> in pretty small steps, it happens in rare cases that the motor instead
> runs forward a quite large amount, possibly hitting the limit switch.
> We have observed this behavior a few times in intervals of some three
> hours. Then again nothing went wrong for days. The problem happened with
> two different axes and on several different MAXv cards (including cards
> with and without the latest bug fix -> see Ron Sluiter's mail "OMS MAXv
> announces fix" from October 27)
> Pro-Dex is informed but they would like to have more input on the
> specific circumstances. Thus my question: Has anyone seen a similar
> effect? Under which circumstances did it happen?
> Dirk
Prev: RE: subrecord INPx Allison, Stephanie
Next: RE: subrecord INPx Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MAXv issue Mark Rivers
Next: fast epid peter.leicester
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
