1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Testing UIs against real databases using simulation mode
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 30 Nov 2010 09:17:15 +1100
Thanks everyone for sending me your tips for this. I really do
appreciate it.
I'm going to go away and digest my options, but I'll post back with
whatever I end up doing and how it works out.
Btw, at the moment, all the devices I'm using are register-based with
custom asynPortDrivers. So I can't make stubs via TCP or other
protocols, unfortunately. Nevertheless, I've tested each port driver
fairly substantially in isolation. So if I can test the GUI/Database
layer independently, it gives me confidence that I can throw everything
together in the facility with the minimum possible integration pain.[1]
- Angus
[1] Famous last words.
Re: Testing UIs against real databases using simulation mode Andrew Johnson
Testing UIs against real databases using simulation mode Angus Gratton
Re: Testing UIs against real databases using simulation mode J. Lewis Muir
Re: Testing UIs against real databases using simulation mode emmanuel_mayssat
Prev: Re: ca_put_callback once again Andrew Johnson
Next: Re: Testing UIs against real databases using simulation mode Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Testing UIs against real databases using simulation mode J. Lewis Muir
ANJ, 29 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
