1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Testing UIs against real databases using simulation mode
To: [email protected]
Date: Mon, 29 Nov 2010 16:57:19 -0600
Hi Angus,
On Monday 29 November 2010 16:17:15 Angus Gratton wrote:
> Btw, at the moment, all the devices I'm using are register-based with
> custom asynPortDrivers. So I can't make stubs via TCP or other
> protocols, unfortunately.
That statement immediately suggests to me that the best place for a simulator
would be to write a generic port driver with a scripted back-end that would
allow you to emulate all of your devices.  I have no experience of doing this
but it sounds like you might be able to embed a Python interpreter or similar
to do the scripting.  However this is just a suggestion, without knowing more
about your particular custom Asyn protocols I can't really say whether it
would be sensible or not.
Good luck!
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Testing UIs against real databases using simulation mode Angus Gratton
Re: Testing UIs against real databases using simulation mode J. Lewis Muir
Re: Testing UIs against real databases using simulation mode Angus Gratton
Prev: Re: Testing UIs against real databases using simulation mode Angus Gratton
Next: Monitoring CPU temperature for small IOC David Morris
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Strange IOC crash Benjamin Franksen
ANJ, 29 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
