1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION
To: [email protected]
Date: Tue, 30 Nov 2010 07:28:26 +0100
Hi Andrew,
On 11/29/10 17:25, Andrew Johnson wrote:
Hi Hinko,
On Thursday 25 November 2010 04:33:31 Hinko Kocevar wrote:
perl /home/hinko/work/epics/install/bin/linux-x86/convertRelease.pl checkRelease EPICS/Release.pm: Circular definition of macro TOP
Please try using absolute paths instead of relative ones in your release files, i.e. paths that (after all the macros have been substituted) start from the root '/' of your directory tree.
That helped.
As an aside, the<base>/configure/RELEASE file should never contain the definition of EPICS_BASE, and it doesn't need EPICS_EXTENSIONS since Base has to be completely built before extensions anyway.
OK. I'll remove them.
Thank you!
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Hinko Kocevar
Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Andrew Johnson
Prev: RE: Monitoring CPU temperature for small IOC Allison, Stephanie
Next: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Ritesh Sugandhi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Andrew Johnson
Next: Testing UIs against real databases using simulation mode Angus Gratton
ANJ, 30 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
