1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Long out record PV Monitoring error in client using CaChannel-1.5 python interface
To: [email protected]
Cc: Di Maio Franck <[email protected]>
Date: Tue, 30 Nov 2010 16:52:49 +0100
Dear Sir,
We are using a client application develop using CaChannel-1.5 epics python interface library. The CA server is exposing a longout record which we are interested in monitoring. When ever the record attends the âive values. The client showsÂÂ2**32-val instead of value.Âwhile the same code works well with ao record type .
The Code is as below:
def eventMon(epics_args, user_args):
ÂÂglobal monPV, now
ÂÂprint monPV, now, epics_args['pv_value']
def main():
ÂÂglobal stop, now
ÂÂtry:
ÂÂ ÂmonChan = CaChannel()
ÂÂ ÂmonChan.search(monPV)
ÂÂ ÂmonChan.pend_io()
ÂÂ Âprint now
ÂÂexcept CaChannelException, status:
ÂÂ Âprint ca.message(status)
ÂÂtry:
ÂÂ ÂmonChan.add_masked_array_event(ca.dbf_type_to_DBR_STS(monChan.field_type()), \
ÂÂ Â Â Â ÂNone, ca.DBE_VALUE | ca.DBE_ALARM, eventMon)
ÂÂwhile not stop:
ÂÂ Ânow = strftime('\t%Y-%m-%d %X\t')
ÂÂ Âca.pend_event(0.5)
Best Regards,
Ritesh SugandhiÂ
RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Pam Gurd
RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Wang Xiaoqiang
Prev: Re: makeBaseApp.pl in 3.14.12 with custom INSTALL_LOCATION Hinko Kocevar
Next: RE: Long out record PV Monitoring error in client using CaChannel-1.5 python interface Pam Gurd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Monitoring CPU temperature for small IOC Allison, Stephanie
ANJ, 01 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
