1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM installing problems on linux-x86
Date: Mon, 6 Dec 2010 15:21:23 +0200
I am new with EPICS am trying to install EDM and the below error keeps appearing.
[root@sesame-10-1-22-37 edm]# make
make -C ./util install
make[1]: Entering directory `/home/MyEpics/extensions/src/edm/util'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/home/MyEpics/extensions/src/edm/util/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/MyEpics/extensions/src/edm/util/O.linux-x86'
make[1]: Leaving directory `/home/MyEpics/extensions/src/edm/util'
make -C ./lib install
make[1]: Entering directory `/home/MyEpics/extensions/src/edm/lib'
make[2]: Entering directory `/home/MyEpics/extensions/src/edm/lib/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -DSINGLE_THREADED=1 -D__epics__=1  -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I../../../../../base/include/os/Linux -I../../../../../base/include  -I../../../../include       -I../../util -I../../lib -I/usr/include -I/usr/include/X11    ../clipbd.cc
../clipbd.cc:19:19: error: Xm/Xm.h: No such file or directory
../clipbd.cc: In member function ‘void clipBdClass::clipbdInit(_WidgetRec*)’:
../clipbd.cc:46: error: ‘xmPrimitiveWidgetClass’ was not declared in this scope
../clipbd.cc:50: error: ‘XmNuserData’ was not declared in this scope
../clipbd.cc: In function ‘Boolean ConvertSelection(_WidgetRec*, Atom*, Atom*, Atom*, void**, long unsigned int*, int*)’:
../clipbd.cc:117: error: ‘XmNuserData’ was not declared in this scope
../clipbd.cc:126: warning: dereferencing type-punned pointer will break strict-aliasing rules
make[2]: *** [clipbd.o] Error 1
make[2]: Leaving directory `/home/MyEpics/extensions/src/edm/lib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/home/MyEpics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
any suggestions ?
Best Regards,
Saed Abu Ghannam.
Re: EDM installing problems on linux-x86 Hinko Kocevar
Re: EDM installing problems on linux-x86 Jack
Prev: Re: New StreamDevice version Craig.Haskins
Next: Re: EDM installing problems on linux-x86 Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Release 3-0 of dxp Mark Rivers
ANJ, 06 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
