1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EDM installing problems on linux-x86
To: [email protected]
Date: Mon, 06 Dec 2010 14:38:03 +0100
See below..
On 12/06/10 14:21, Saed Abu Ghannam wrote:
I am new with EPICS am trying to install EDM and the below error keeps
appearing.
*[root@sesame-10-1-22-37 edm]# make*
*make -C ./util install*
*make[1]: Entering directory `/home/MyEpics/extensions/src/edm/util'*
*make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install*
*make[2]: Entering directory
`/home/MyEpics/extensions/src/edm/util/O.linux-x86'*
*make[2]: Nothing to be done for `install'.*
*make[2]: Leaving directory
*make[1]: Leaving directory `/home/MyEpics/extensions/src/edm/util'*
*make -C ./lib install*
*make[1]: Entering directory `/home/MyEpics/extensions/src/edm/lib'*
`/home/MyEpics/extensions/src/edm/lib/O.linux-x86'*
*/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT
-ansi -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m32 -g -fPIC -I.
-I../O.Common -I. -I.. -I../../../../include/edm/os/Linux
-I../../../../include/edm -I../../../../../base/include/os/Linux
-I../../../../../base/include -I../../../../include -I../../util
-I../../lib -I/usr/include -I/usr/include/X11 ../clipbd.cc*
*../clipbd.cc:19:19: error: Xm/Xm.h: No such file or directory*
Here is your problem - Xm.h is missing.. I think you need development libraries for Motif package..
Best regards, Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies d.d.
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
EDM installing problems on linux-x86 Saed Abu Ghannam
Prev: EDM installing problems on linux-x86 Saed Abu Ghannam
Next: Re: EDM installing problems on linux-x86 Jack
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 06 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
