1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Base-3.14.12 (win32) on win 7 64 bit system compilation
To: Kazimierz Gofron <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 7 Dec 2010 11:04:16 -0600
Hi Kaz,
I'm cross-posting this reply to tech-talk as it seems to be a common issue.
On Tuesday 07 December 2010 10:13:23 Kazimierz Gofron wrote:
> cl -c           -DDEFAULT_SKELETON_FILE=include/flex.skel.static    /nologo
> /D__ STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE   /Ox
> /GL   /W1 /MD     -I. -I..\\O.Common -I. -I..
> -I..\\..\\..\\..\\include\\os\\WIN32 - I..\\..\\..\\..\\include
> ..\\tblcmp.c
> tblcmp.c
> perl -MExtUtils::Command -e rm_f parse.c y.tab.c
> perl -MExtUtils::Command -e rm_f parse.h y.tab.h
> ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
> make[4]: *** [parse.c] Error 127
> make[4]: Leaving directory
> `/cygdrive/c/epics/base-3.14.12/src/toolsComm/flex/O. win32-x86'
> make[3]: *** [install.win32-x86] Error 2
> make[3]: Leaving directory
Note that this is the first time the build tries to actually run a C program
(antelope.exe) that it has just compiled.  GNUmake isn't able to execute the
antelope command line.
This has nothing to do with the fact that you're using Windows 7 or a 64-bit
system.  The problem is that you're using the Cygwin version of make to build
a non-Cygwin target (win32-x86).  While it might be possible to do this it's
hard to do and very confusing to work with, since the Windows tools don't
understand /cygdrive/ paths, and I suspect your Cygwin make doesn't like the
\\ parts of the command-line it's using to run antelope.  I can't help you
with getting this mixed tool approach to work since I've never done it,
although Janet or Mark Rivers might have some experience.
My recommendation to fix this is that you install a native Windows version of
GNUmake such as the one that comes with the MinGW tools, and while you're at
it make sure that your version of Perl is similarly Windows native and not
from Cygwin (either the ActiveState or Strawberry Perl distributions would be
good).
Use Cygwin tools only to build cygwin-x86 targets, and Windows tools to build
win32-x86 and windows-x64 targets.  As far as EPICS is concerned, Cygwin is a
different operating system than Windows.
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Prev: Re: New StreamDevice version Dirk Zimoch
Next: RE: Base-3.14.12 (win32) on win 7 64 bit system compilation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM installing problems on linux-x86 Jack
ANJ, 07 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
