1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Base-3.14.12 (win32) on win 7 64 bit system compilation
To: "Kazimierz Gofron" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Tue, 7 Dec 2010 11:32:01 -0600
Andrew and Kaz,
I successfully built EPICS base 3.14.12-rc1 and all of synApps using an older version of Cygwin make (before they discontinued support for Windows path names).  The rest of Cygwin was 1.7.7.  I built them with that Cygwin make for both the win32-x86 and cygwin-x86 architectures on Windows XP 32-bit.
Sent: Tuesday, December 07, 2010 11:12 AM
To: Andrew Johnson
Cc: Mark Rivers
Subject: Re: Base-3.14.12 (win32) on win 7 64 bit system compilation
The process worked up to base-3-14-11 (inclusive), and does not work in newest base 3.14.12...
Something must have changed.
----- Original Message -----
Date: Tuesday, December 7, 2010 11:04 am
To: Kazimierz Gofron <[email protected]>
Cc: EPICS tech-talk <[email protected]>
> Hi Kaz,
> I'm cross-posting this reply to tech-talk as it seems to be a
> common issue.
> On Tuesday 07 December 2010 10:13:23 Kazimierz Gofron wrote:
> > cl -
> c           -
> DDEFAULT_SKELETON_FILE=include/flex.skel.static    /nologo
> > /D__ STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
> /D_CRT_NONSTDC_NO_DEPRECATE   /Ox
> > /GL   /W1 /MD     -I. -
> I..\\O.Common -I. -I..
> > -I..\\..\\..\\..\\include\\os\\WIN32 -
> > ..\\tblcmp.c
> > tblcmp.c
> > perl -MExtUtils::Command -e rm_f parse.c y.tab.c
> > perl -MExtUtils::Command -e rm_f parse.h y.tab.h
> > ..\\..\\..\\..\\bin\\win32-x86\\antelope.exe -l -d ../parse.y
> > make[4]: *** [parse.c] Error 127
> > make[4]: Leaving directory
> > `/cygdrive/c/epics/base-3.14.12/src/toolsComm/flex/O. win32-x86'
> > make[3]: *** [install.win32-x86] Error 2
> > make[3]: Leaving directory
> Note that this is the first time the build tries to actually run
> a C program
> (antelope.exe) that it has just compiled.  GNUmake isn't
> able to execute the
> antelope command line.
> This has nothing to do with the fact that you're using Windows 7
> or a 64-bit
> system.  The problem is that you're using the Cygwin
> version of make to build
> a non-Cygwin target (win32-x86).  While it might be
> possible to do this it's
> hard to do and very confusing to work with, since the Windows
> tools don't
> understand /cygdrive/ paths, and I suspect your Cygwin make
> doesn't like the
> \\ parts of the command-line it's using to run antelope.  I
> can't help you
> with getting this mixed tool approach to work since I've never
> done it,
> although Janet or Mark Rivers might have some experience.
> My recommendation to fix this is that you install a native
> Windows version of
> GNUmake such as the one that comes with the MinGW tools, and
> while you're at
> it make sure that your version of Perl is similarly Windows
> native and not
> from Cygwin (either the ActiveState or Strawberry Perl
> distributions would be
> good).
> Use Cygwin tools only to build cygwin-x86 targets, and Windows
> tools to build
> win32-x86 and windows-x64 targets.  As far as EPICS is
> concerned, Cygwin is a
> different operating system than Windows.
> HTH,
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming,
> he will
> refuse to believe it.  If, on the other hand, he is offered
> somethingwhich affords a reason for acting in accordance to his
> instincts, he
> will accept it even on the slightest evidence.  -- Bertrand
> Russell
Re: Base-3.14.12 (win32) on win 7 64 bit system compilation Janet Anderson
Re: Base-3.14.12 (win32) on win 7 64 bit system compilation Andrew Johnson
Prev: Re: Base-3.14.12 (win32) on win 7 64 bit system compilation Andrew Johnson
Next: Re: Base-3.14.12 (win32) on win 7 64 bit system compilation Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
