1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to cross compile procServ?
To: "Dirk Zimoch" <[email protected]>
Cc: [email protected]
Date: Tue, 14 Dec 2010 09:25:41 -0500
Dirk,
My apologies if this wasn't clear.  I saw your message just before I
left for the day.
> -----Original Message-----
> Davidsaver, Michael wrote:
> > Hi Dirk,
> > 1) Export the following before running configure.  Value (yes/no)
> > depending on your environment.
The simplest thing to do is bypass the test by setting the result.
$ export ac_cv_func_setpgrp_void=yes
$ ./configure
> > 2) Comment out the test in configure.in and run 'autoreconf'.
This is another solution.  You only need to do 1) or 2) not both.
> Hi Michael
> There is no configure.in, only configure.ac and configure.
I meant configure.ac ...
> There are Makefile.in and Makefile.Epics.in. Does that help?
> Dirk
> >> From: [email protected] [mailto:tech-talk-
> >> [email protected]] On Behalf Of Dirk Zimoch
> >> Sent: Monday, December 13, 2010 5:27 PM
> >> To: EPICS
> >> Subject: How to cross compile procServ?
> >> When trying to cross compile, the configure script fails with:
> >> checking whether setpgrp takes no argument... configure: error:
> cannot
> >> check setpgrp when cross compiling
> >> How can I cross compile procServ (for embedded Linux) ?
> >> Dirk
How to cross compile procServ? Dirk Zimoch
RE: How to cross compile procServ? Davidsaver, Michael
Re: How to cross compile procServ? Dirk Zimoch
Prev: Re: How to cross compile procServ? Ralph Lange
Next: Andor driver for areaDetector? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: About PCAS Access Control 张玉亮
ANJ, 14 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
