Should be configure.ac - which lists the tests that autoconf should put
into the configure script. Comment out AC_FUNC_SETPGRP in that file.
This setpgrp test, while being one of autoconf's standard tests, does
not work in cross-compiling environments. I will have to replace it with
an equivalent test that also works when cross-compiling.
I created a Trac bug report on procServ's Sourceforge project for this.
[1] Thanks for bringing it to my attention.
If you compile procServ within an EPICS project, you can use that
project's configuration instead of using autoconf. See `configure
--help` (option "--with-epics-top") for details.
Sorry for the inconvenience!
Ralph
[1] https://sourceforge.net/apps/trac/procserv/ticket/26
On 14.12.2010 11:28 Dirk Zimoch wrote:
Davidsaver, Michael wrote:
Hi Dirk,
1) Export the following before running configure. Value (yes/no)
depending on your environment.
export ac_cv_func_setpgrp_void=yes
2) Comment out the test in configure.in and run 'autoreconf'.
Hi Michael
There is no configure.in, only configure.ac and configure.
There are Makefile.in and Makefile.Epics.in. Does that help?
Dirk
-----Original Message-----
[email protected]] On Behalf Of Dirk Zimoch
Sent: Monday, December 13, 2010 5:27 PM
To: EPICS
Subject: How to cross compile procServ?
When trying to cross compile, the configure script fails with:
checking whether setpgrp takes no argument... configure: error: cannot
check setpgrp when cross compiling
How can I cross compile procServ (for embedded Linux) ?
Dirk
- How to cross compile procServ? Dirk Zimoch
- RE: How to cross compile procServ? Davidsaver, Michael
- Re: How to cross compile procServ? Dirk Zimoch
<2010>
2025
2026
<2010>
2025
2026
ANJ, 14 Dec 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
