(10/12/19 22:06), Saed Abu Ghannam wrote:
> Hi all,
> when I try to install the alarm handler or EDM or even the MEDM, I always got the same below error:
> make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
> make[1]: Entering directory `/root/EPICS_TOP/extensions/src/alh1_2_24/O.linux-x86'
> /usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -O3 -Wall -m32 -g -I. -I../O.Common -I. -I../os/default -I.. -I../../../include/os/Linux -I../../../include -I../../../../base/include/os/Linux -I../../../../base/include -I../../../include -I../os/Linux -I../os/default -I/root/Desktop/openmotif-2.3.1/include -I/usr/include/X11 ../alCA.c
> In file included from ../ax.h:27,
> from ../alCA.c:24:
> ../alh.h:26:19: error: Xm/Xm.h: No such file or directory
> ../alh.h:27:26: error: Xm/RowColumn.h: No such file or directory
> from ../alCA.c:24:
> ../alh.h:155: warning: parameter names (without types) in function declaration
> ../alh.h:156: error: expected specifier-qualifier-list before ‘XtPointer’
> ../alh.h:164: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
> ../alh.h:165: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘appContext’
> ../alh.h:166: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘topLevelShell’
> ../alh.h:167: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘productDescriptionShell’
> ../alh.h:168: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ALH_pixmap’
> ../alh.h:176: error: expected specifier-qualifier-list before ‘XtIntervalId’
> In file included from ../ax.h:28,
> from ../alCA.c:24:
> ../axSubW.h:32: error: expected specifier-qualifier-list before ‘Widget’
> In file included from ../ax.h:29,
> from ../alCA.c:24:
> ../line.h:52: error: expected specifier-qualifier-list before ‘Widget’
> In file included from ../ax.h:30,
> from ../alCA.c:24:
> ../alLib.h:61: error: expected specifier-qualifier-list before ‘XtIntervalId’
> ../alLib.h:111: error: expected specifier-qualifier-list before ‘XtIntervalId’
> ../alLib.h:128: error: expected specifier-qualifier-list before ‘XtIntervalId’
> ../alLib.h:151: error: expected specifier-qualifier-list before ‘XtIntervalId’
> In file included from ../alCA.c:24:
> ../ax.h:54: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:71: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:73: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:121: error: expected declaration specifiers or ‘...’ before ‘XmFileSelectionBoxCallbackStruct’
> ../ax.h:122: error: expected declaration specifiers or ‘...’ before ‘XmFileSelectionBoxCallbackStruct’
> ../ax.h:130: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:138: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
> ../ax.h:140: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
> ../ax.h:142: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
> ../ax.h:144: error: expected declaration specifiers or ‘...’ before ‘XmPushButtonCallbackStruct’
> ../ax.h:161: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:394: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:395: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:397: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> ../ax.h:411: error: expected declaration specifiers or ‘...’ before ‘XmAnyCallbackStruct’
> make[1]: *** [alCA.o] Error 1
> make[1]: Leaving directory `/root/EPICS_TOP/extensions/src/alh1_2_24/O.linux-x86'
> make: *** [install.linux-x86] Error 2
> which means Xm.h is missing, and this requires to install open motif,
On Ubuntu, installing "libmotif-dev" may be enough to compile medm and
others.
> my question how do we install openmotif and from where we get the correct version and where do we install
> it in reference with the EDM or MEDM directory? Any suggestions ?
How about the following URI?
http://www.openmotif.org/
> best resgards,
> saed.
Noboru
J-PARC control group
KEK
- openmotif installtion problems. Saed Abu Ghannam
Re: openmotif installtion problems. Mauro Giacchini
Re: building latest snapshot of streamDevice Dirk Zimoch
<2010>
2025
2026
epics under NET OS Yuriy Gorbunov
<2010>
2025
2026
