1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error compiling waveProc1-0 on base 3.14.12
To: <[email protected]>
Date: Thu, 23 Dec 2010 12:55:37 +1100
Hi Eric,
Thanks for your response. The problem is because of the following definition in my RELEASE file (we need to install in a different location relative to TOP):
INSTALL_LOCATION_APP=$(TOP)/../install
Apparently Release.pm does not like $(TOP) in the iNSTALL_LOCATION_APP variable. All the other support modules we are using (asyn, sncseq, modbus) have a similar definition and Release.pm does not complain. Do you know why waveProc is somewhat different to asyn or sncseq?
Cheers,
  Juan Carlos.
P.S.: I'm using MacOSX 10.6.5 (darwin-x86)
On 22/12/2010, at 1:03 PM, Eric Norum wrote:
Have you made any changes to the Makefiles?  What version of OS X are you using?
Here's what I did this morning to check this:
1) Downloaded and unpacked waveProc1-0.tar.gz<http://www.aps.anl.gov/epics/download/modules/waveProc1-0.tar.gz>.
2) Edited the configure/RELEASE file and changed the EPICS_BASE assignment to
EPICS_BASE=/usr/local/epics/R3.14.12/base
3) Ran 'make' -- things built fine.
I tried this on both darwin-x86 (10.6.5) and linux-x86_64 hosts and for RTEMS-mvme2100 and RTEMS-mvme3100 targets.
On Dec 22, 2010, at 6:47 AM, <[email protected]<mailto:[email protected]>> wrote:
When compiling waveProc1-0 under base 3.14.12 the following error is displayed:
EPICS/Release.pm: Circular definition of macro TOP
make -C ./configure install
make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
perl /Users/guz006/SwDev/UNDER_MOD/askapsoft/Src/trunk/3rdParty/EPICS/3.14.12/base/install/bin/darwin-x86/convertRelease.pl checkRelease
make[2]: *** [checkRelease] Error 2
make[1]: *** [install.darwin-x86] Error 2
make: *** [configure.install] Error 2
Under 3.14.11 waveProc compiles ok. It seems that Release.pm is more restrictive now compares with previous version. I'm not sure who is correct the new version of Release.pm or waveProc? I could not identify where in waveProc is the circular definition of macro TOP.
Any help would be much appreciated.
 Juan Carlos.
Juan Carlos Guzman
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]<mailto:[email protected]>
Eric Norum
Juan Carlos Guzman
Software Engineer
Re: Error compiling waveProc1-0 on base 3.14.12 Andrew Johnson
Error compiling waveProc1-0 on base 3.14.12 Juan.Guzman
Re: Error compiling waveProc1-0 on base 3.14.12 Eric Norum
Prev: Re: Error compiling waveProc1-0 on base 3.14.12 Eric Norum
Next: Re: Error compiling waveProc1-0 on base 3.14.12 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 22 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
