1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error compiling waveProc1-0 on base 3.14.12
To: Juan Guzman <[email protected]>
Cc: [email protected]
Date: Wed, 22 Dec 2010 21:23:50 -0600 (CST)
Hi Juan,
> The problem is because of the following
> definition in my RELEASE file (we need to install in a different
> location relative to TOP):
> INSTALL_LOCATION_APP=$(TOP)/../install
> Apparently Release.pm does not like $(TOP) in the INSTALL_LOCATION_APP
> variable. All the other support modules we are using (asyn, sncseq,
> modbus) have a similar definition and Release.pm does not complain. Do
> you know why waveProc is somewhat different to asyn or sncseq?
You're not supposed to use $(TOP) at all in a RELEASE file; RELEASE is special in the EPICS build system and should not be used for setting any variables other than pointers to other support applications.  The right place to set other variables is in the module's configure/CONFIG_SITE file instead (or the related architecture-specific files).
The waveProc application hasn't been updated in a while and might have some rather old versions of the configure/* files, so you might want to try replacing everything in its configure directory with the contents of <base>/templates/makeBaseApp/top/configure instead (especially if the comments in the existing files contradict what I've written above).
HTH,
- Andrew
Re: Error compiling waveProc1-0 on base 3.14.12 Juan.Guzman
Prev: Re: Error compiling waveProc1-0 on base 3.14.12 Juan.Guzman
Next: APS Network Maintenance after December 26th Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Error compiling waveProc1-0 on base 3.14.12 Juan.Guzman
ANJ, 23 Dec 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
