1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: GPIB to ethernet converter
To: Richard Farnsworth <[email protected]>, matthew pearson <[email protected]>
Date: Mon, 10 Jan 2011 09:51:49 -0800
We used a microioc for GPIB control in PEP-II. The GPIB device was balky and we had switchable power outlets put into the microIOC as well, for power cycling the GPIB device when it hung badly. The whole thing worked very well.
Ron Chestnut
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Richard Farnsworth
Sent: Monday, January 10, 2011 6:57 AM
To: matthew pearson
Cc: [email protected]
Subject: Re: GPIB to ethernet converter
We also had the E5810As at the Australian Synchrotron. Never needed to boot as far as I recalled - although the GPIB devices further downstream often caused issues.
As for cost - well, it's only money. We also used a Cosylab MicroIOC with a card for GPIB interfaces. Cost was about the same and you got the whole IOC at the same time. Check out http://www.microioc.com/ if you want to.
Cheers,
Richard
Ex Australian Synchrotron, now at the APS.
----- Original Message -----
To: "c walther" <[email protected]>, [email protected]
Sent: Monday, January 10, 2011 6:34:48 AM
We also have a couple of these E5810As at Diamond. I had the same
experience... fairly reliable, easy to use (with a web interface). Very
occasionally need to reboot. But expensive.
Cheers,
Matt
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Craig Walther
> Sent: 06 January 2011 00:43
> To: EPICS tech-talk
> Hi Emmanuel:
> We are using a few Agilent Tech. E5810As.  They are easy to use and
> seem
> reliable, however sometimes they require a power cycle. I am also not
> certain I would call them inexpensive.
> Craig
> > I have a few GPIB devices.
> > I am trying to phase them out whenever possible.
> > Is there an inexpensive GPIB to ethernet converted that you would
> recomend?
> > Regards,
> Craig Walther
> Joint Astronomy Centre
> 660 North A'ohoku Place
> Hilo, Hawaii 96720  USA
> [email protected]
> (808) 969-6556  (office)
> (808) 961-6516  (fax)
RE: GPIB to ethernet converter matthew.pearson
Re: GPIB to ethernet converter Richard Farnsworth
Prev: Re: GPIB to ethernet converter Richard Farnsworth
Next: RE: MOXA terminal server Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: GPIB to ethernet converter Cyrus Reed
