1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Mapping Using Java Annotations
To: Mitch McCuiston <[email protected]>
Cc: [email protected]
Date: Tue, 11 Jan 2011 09:40:00 -0600
On 1/10/11 6:12 PM, Mitch McCuiston wrote:
>  I've been thinking about implementing an annotation based mapping of
> Java objects to PVs.  I thought I would ask the community if something
> like this already exists before I take it on.  If it doesn't exist,
> would anyone find value in this.  The idea is loosely based on how
> Hibernate maps Java objects to a relational database, although the
> read/write semantics are a little different.  Here is an example.
Hi, Mitch.
I don't really see why one would use annotations for this.  I'd
certainly be in favor of an object implementation in Java above JCA/CAJ
(or perhaps added to it) that would provide a simple and easy-to-use API
for interacting w/ EPICS PVs.  At a minimum, it would provide an EpicsPv
object and make it easy to get and set values, easy to register interest
in a value change, do blocking puts, and more.  I've written such an
implementation, but there are a lot of changes and improvements it needs
before I'd make it publicly available.
So I'd say, yes, there's a need for a simple and easy-to-use API on top
of JCA/CAJ -- something perhaps along the lines of Matt Newville's Epics
Channel Access for Python
<http://cars9.uchicago.edu/software/python/pyepics3/> which provides a
PV class.  But I don't see any reason to use annotations.  Why do you
want to use annotations rather than just regular objects?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
Re: PV Mapping Using Java Annotations Mitch McCuiston
Prev: RE: MOXA terminal server emma.shepherd
Next: RE: PV Mapping Using Java Annotations Carcassi, Gabriele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PV Mapping Using Java Annotations Mitch McCuiston
Next: Re: PV Mapping Using Java Annotations Mitch McCuiston
