On Tuesday 11 January 2011 23:56:33 [email protected] wrote:
> I tried to build seq-2.0.11 with base-3.14.12 on CentOS 5.5 to
> find that it fails. (I attatch the log messages below this writing.)
> It looks like the problem is something under base/configure though
> I'm not sure on this point.
The latest non-experimental released version of the sequencer is 2.0.12, which
does build with 3.14.12.
If you prefer to modify your 2.0.11 installation though, you will need to
remove all mention of the iocsh library from the src/seq/Makefile — it was
merged into libCom in Base 3.14.10. Under src/snc/Makefile you should also
remove the lines setting SYS_PROD_LIBS_Linux and SYS_PROD_LIBS_DEFAULT. There
were some other changes between 2.0.11 and 2.0.12, but I'm not sure if they're
essential; it will probably be quicker to just download 2.0.12.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
- Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
EPICS support for Harvard PHD Ultra syringe pump tom.cobb
RE: Problem using large arrays with Channel Access in EPICS 3.14.12 Jeff Hill
<2011>
2025
2026
<2011>
2025
2026
