1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building seq-2.0.11 with base-3.14.12
To: "Andrew Johnson" <[email protected]>
Cc: [email protected]
Date: Thu, 13 Jan 2011 08:38:31 +0900
Hi, Andrew and all;
> The latest non-experimental released version of the sequencer is 2.0.
12, which
> does build with 3.14.12.
It's just that I wasn't aware of it. I've tried sncseq-2.0.12 with
base-3.14.12. I've built it without any problems. I'd like to thank
all of you who kindly let me know with rapid responses.
Thank you very much!
Jun-ichi
----- Original Message -----
> Hi,
> On Tuesday 11 January 2011 23:56:33 [email protected] wrote:
> > I tried to build seq-2.0.11 with base-3.14.12 on CentOS 5.5 to
> > find that it fails. (I attatch the log messages below this writing.)
> > It looks like the problem is something under base/configure though
> > I'm not sure on this point.
12, which
> If you prefer to modify your 2.0.11 installation though, you will need
to
> remove all mention of the iocsh library from the src/seq/Makefile — it
was
> merged into libCom in Base 3.14.10.  Under src/snc/Makefile you should
also
> remove the lines setting SYS_PROD_LIBS_Linux and SYS_PROD_LIBS_DEFAULT.
  There
> were some other changes between 2.0.11 and 2.0.12, but I'm not sure if
they're
> essential; it will probably be quicker to just download 2.0.12.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he
will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Building base-3.14.12 for a specific target jun-ichi.odagiri
Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
Re: Building seq-2.0.11 with base-3.14.12 Andrew Johnson
Prev: RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Next: Re: Errors in building areaDetector Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building seq-2.0.11 with base-3.14.12 Andrew Johnson
Next: Building base-3.14.12 for a specific target jun-ichi.odagiri
