I did it, and commented "DIRS+=tiffSuppport" in ADApp/Makefile. The building
has ended without any errors.
Thank you very much!
Mi Qingru
SSRF
021-33933238
-----原始邮件-----
Sent: Wednesday, January 12, 2011 9:22 PM
To: Mi Qingru ; tech-talk epics
Subject: RE: Errors in building areaDetector
The problem is that Centos4.4 is quite old, from 2006. The versions of
libtiff and libjpeg that I distribute with areaDetector are built on a more
recent version of Linux, and won't work on that old version.
You can fix the problem by installing versions of libtiff and libjpeg on
your system that are compatible with Centos4.4. Then change the Makefile in
the marCCDApp to use the system versions of these libraries, rather than the
versions included in areaDetector. There are comments in the Makefile that
explain that.
Sent: Wed 1/12/2011 1:01 AM
To: tech-talk epics
Subject: Errors in building areaDetector
I builds areaDetectorR1-6 on CentOS4.4. I have built all support modules
such as asyn, sscan. The following are the errors when building
areaDetector.
/usr/bin/g++ -o
marCCDApp -Wl,-Bstatic -L/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86 -L/BLC/epics/base-3-14-11/lib/linux-x86
-L/BLC/epics/modules/asyn4-13-1/lib/linux-x86 -L/BLC/epics/modules/autosave-4-7/lib/linux-x86
-L/BLC/epics/modules/busy-1-3/lib/linux-x86 -L/BLC/epics/modules/calc-2-8/lib/linux-x86
-L/BLC/epics/modules/mcaR6-12-1/lib/linux-x86 -L/BLC/epics/modules/sscan-2-6-6/lib/linux-x86
-Wl,-rpath,/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86 -Wl,-rpath,/BLC/epics/base-3-14-11/lib/linux-x86
-Wl,-rpath,/BLC/epics/modules/asyn4-13-1/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/autosave-4-7/lib/linux-x86
-Wl,-rpath,/BLC/epics/modules/busy-1-3/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/calc-2-8/lib/linux-x86
-Wl,-rpath,/BLC/epics/modules/mcaR6-12-1/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/sscan-2-6-6/lib/linux-x86
-m32 marCCDApp_registerRecordDeviceDriver.o
marCCDAppMain.o -lmarCCD_AD -lNDPlugin -lADBase -lnetCDF -lcalc -lbusy -lsscan
-lautosave -lmca -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc
-lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lPvAPI -lImageLib -lNeXus
-lmfhdf -ldf -lhdf5 -lmxml -ltiff -ljpeg -lz -Wl,-Bdynamic -lpthread -lreadline
-lncurses -lm -lrt -ldl -lgcc
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_dirread.o)(.text+0x210c):
In function `TIFFReadDirectory':
: undefined reference to `__stack_chk_fail'
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_dirwrite.o)(.text+0x1b73):
In function `_TIFFWriteDirectory':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_jpeg.o)(.text+0x626):
In function `TIFFjpeg_output_message':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jchuff.o)(.text+0x518):
In function `jpeg_make_c_derived_tbl':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jchuff.o)(.text+0x9e2):
In function `jpeg_gen_optimal_table':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jdmarker.o)(.text+0x94f):
more undefined references to `__stack_chk_fail' follow
collect2: ld returned 1 exit status
make[3]: *** [marCCDApp] Error 1
make[3]: Leaving directory
`/BLC/epics/modules/areaDetectorR1-6/ADApp/marCCDSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/BLC/epics/modules/areaDetectorR1-6/ADApp/marCCDSrc'
make[1]: *** [marCCDSrc.install] Error 2
make[1]: Leaving directory `/BLC/epics/modules/areaDetectorR1-6/ADApp'
make: *** [ADApp.install] Error 2
Mi Qingru
SSRF
021-33933238
- Errors in building areaDetector Mi Qingru
- RE: Errors in building areaDetector Mark Rivers
Re: Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Mark Rivers
<2011>
2025
2026
EPICS support for Harvard PHD Ultra syringe pump tom.cobb
<2011>
2025
2026
