Hi Jeff,
Thanks for the quick response. I installed the patch and it fixes the problem.
Sent: Wed 1/12/2011 5:21 PM
To: [email protected]
Subject: RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12
I committed a fix to the R3.14 branch. An overzealous optimization was
installed. See bug 701673 at launchpad for the details.
https://bugs.launchpad.net/epics-base/+bug/701673
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Jeff Hill [mailto:[email protected]]
> Sent: Wednesday, January 12, 2011 9:27 AM
> To: '[email protected]'
> Subject: RE: Problem using large arrays with Channel Access in EPICS
> 3.14.12
> Yes, there were two new features merged into CA for the R3.14.12 patch
> release. I will have a look.
> PS: IMHO, we can consider that risk is reduced if only patches are merged
> into patch releases. Perhaps new features are best placed in point
> releases.
> Jeff
> > From: [email protected] [mailto:tech-talk-
> > [email protected]] On Behalf Of Andrew Johnson
> > Sent: Tuesday, January 11, 2011 2:43 PM
> > Subject: Re: Problem using large arrays with Channel Access in EPICS
> > 3.14.12
> > On Tuesday 11 January 2011 15:21:32 Till Straumann wrote:
> > > Could be a limitation of the CA protocol
> > No, this is as a result of changes in src/rsrv between 3.14.11 and
> > 3.14.12
> > because large arrays work fine in 3.14.11.
> > We introduced two major new features in the latest release, CA over TCP
> > and
> > dynamic array sizing, and one of them (most probably the latter) has
> > broken
> > the correct reporting of the element count. The CA protocol solved the
> > problem of only a having a 16 bit m_count field a long time ago, but it
> > looks
> > like that hack^H^H^H^Hsolution didn't get propagated into the latest
> > code.
> > - Andrew
> > If a man is offered a fact which goes against his instincts, he will
> > scrutinize it closely, and unless the evidence is overwhelming, he will
> > refuse to believe it. If, on the other hand, he is offered something
> > which affords a reason for acting in accordance to his instincts, he
> > will accept it even on the slightest evidence. -- Bertrand Russell
- RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Michael Abbott
- Problem using large arrays with Channel Access in EPICS 3.14.12 Mark Rivers
- Re: Problem using large arrays with Channel Access in EPICS 3.14.12 Till Straumann
- Re: Problem using large arrays with Channel Access in EPICS 3.14.12 Andrew Johnson
- RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Re: Errors in building areaDetector Mi Qingru
<2011>
2025
2026
<2011>
2025
2026
