Hello John,
I have seen the same behavior recently, while trying to produce drivers
for a home-made scaler connecting to EPICS through a serial port. The
solution was to define very carefully all the timing as well as the
terminator parameters in the protocol file. Here is what mine looks
like:
InTerminator = ;
ExtraInput = Ignore;
OutTerminator = CR;
ReplyTimeout = 500;
ReadTimeout = 10;
PollPeriod = 10;
These values were determined after some experimentation and seem to
produce the desirable behavior in my case. I would suggest you have a
read at the EPICS StreadDevice documentation, especially the section
titled "System Variables" that describes the use of these variables.
Hope this helps,
Dimitris
On Tue, 2011-01-18 at 12:00 -0600, [email protected] wrote:
> Date: Mon, 17 Jan 2011 16:23:00 -0500
> From: John Dobbins <[email protected]>
> To: EPICS Tech-Talk <[email protected]>
> Subject: StreamDevice/ASYN connection to a Telnet port
> Message-ID:
> <8C7BE07847F60A4FB9DF545CFFBC2D8C35039B5C37@MBXC.exchange.cornell.edu>
> Content-Type: text/plain; charset="us-ascii"
> Dear All,
> I am connecting to a Gamma Vacuum SPCe ion pump power supply. This device has an ethernet port which accepts telnet connections.
> I set up StremDevice to communicate with it on port 23,
> I have asyn Trace Masks set as follows:
> asynSetTraceMask("SPCe",-1,0x09)
> asynSetTraceIOMask("SPCe",-1,0x2
> I have a problem in that the response string , which I expect to look like "OK 00 7.90E-13 TORR"
> appears like this:
> epics> 2011/01/17 16:14:55.995 172.18.32.21:23 write 7
> spc 0B\r
> 2011/01/17 16:14:56.475 172.18.32.21:23 read 1
> O
> K
> 0
> 0
> 2011/01/17 16:14:56.476 172.18.32.21:23 read 1
> 7
> 9
> 2011/01/17 16:14:56.477 172.18.32.21:23 read 1
> 0
> E
> 1
> 2011/01/17 16:14:56.478 172.18.32.21:23 read 1
> 3
> T
> O
> R
> 2011/01/17 16:14:56.479 172.18.32.21:23 read 1
> R
> \r
> Can someone tell me what is going on here?
> Regards and thanks,
> John Dobbins
> Cornell University
> Lab for Elementary Particle Physics
Mail: [email protected]
WWW: http://wwwrsphysse.anu.edu.au/nuclear/
Phone: +61-2-6125 2088
Fax: +61-2-6125 0748
Dept. of Nuclear Physics
Research School of Physics and Engineering
Australian National University
Canberra ACT 0200 AUSTRALIA
About subArray trailing zeros Zhang, Jihong (Julia)
RE: About subArray trailing zeros Szalata, Zenon M.
<2011>
2025
2026
Re: StreamDevice/ASYN connection to a Telnet port John Dobbins
Spilt the waveform by different indices in DB 勇克
<2011>
2025
2026
