1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS BOY Meter widget limits
To: "Pawel Predki" <[email protected]>, "Kasemir, Kay" <[email protected]>
Cc: TechTalk <[email protected]>
Date: Tue, 25 Jan 2011 09:50:32 -0600
What if you change "Raw Soft Channel" to "Soft Channel".  Normally one would use quotes around the values, right?
     field(HIHI,"8.0")
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pawel Predki
Sent: Tuesday, January 25, 2011 9:44 AM
To: Kasemir, Kay
Cc: TechTalk
Subject: Re: CSS BOY Meter widget limits
W dniu 2011-01-25 16:24, Kasemir, Kay pisze:
> Hello:
> On 1/25/11 10:17 , "Paweł Prędki"<[email protected]>  wrote:
>> The thing is the HIHI, HIGH, LOW and LOLO values are initialized in the
>> record but BOY doesn't seem to be loading them. The record I'm referring
>> to is as follows:
>> record(ao,DISK:FORWARDING") {
>>     field(DESC,"Forwarding Throughput")
>>     field(DTYP,"Raw Soft Channel")
>>     field(EGU,"Gbps")
>>     field(OMSL,"supervisory")
>>     field(DRVL,0.0)
>>     field(DRVH,10.0)
>>     field(LOPR,0.0)
>>     field(HOPR,10.0)
>>     field(HIHI,8.0)
>>     field(HIGH,7.0);
>>     field(LOW, 1.0);
>>     field(LOLO,0.0)
> Not sure about the quotes in this example.
> Does the IOC load the database without errors?
> Try caget to read the value as a DBR_CTRL_DOUBLE:
>    caget -d 34 DISK:FORWARDING
> It should also show NaN (actually nan) for fields that the IOC reports as
> not initialized.
> -Kay
Hello,
You are right - I get nan for the lo/hi warn/alarm fields using caget.
It doesn't matter if I use the quotes or not. The IOC doesn't display
any errors when loading this db.
Does the fact that the native data type is DBF_DOUBLE have anything to
do with it? I wonder why only those four fields are invalid in this case.
Pawel
Re: CSS BOY Meter widget limits Kasemir, Kay
Re: CSS BOY Meter widget limits Paweł Prędki
Prev: Re: CSS BOY Meter widget limits Paweł Prędki
Next: Re: CSS BOY Meter widget limits Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
