1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BOY Meter widget limits
To: [email protected]
Date: Tue, 25 Jan 2011 09:55:57 -0600
Hi Paweł,
On Tuesday 25 January 2011 09:17:08 Paweł Prędki wrote:
> The thing is the HIHI, HIGH, LOW and LOLO values are initialized in the
> record but BOY doesn't seem to be loading them. The record I'm referring
> to is as follows:
> record(ao,DISK:FORWARDING") {
>    field(DESC,"Forwarding Throughput")
>    field(DTYP,"Raw Soft Channel")
>    field(EGU,"Gbps")
>    field(OMSL,"supervisory")
>    field(DRVL,0.0)
>    field(DRVH,10.0)
>    field(LOPR,0.0)
>    field(HOPR,10.0)
>    field(HIHI,8.0)
>    field(HIGH,7.0);
>    field(LOW, 1.0);
>    field(LOLO,0.0)
The IOC also checks that you have something other than NO_ALARM in the
relevant xxSV field before it will provide the limit through CA, otherwise it
would have no way to tell whether your LOLO limit is an alarm limit or just
the default value for the LOLO field.  You must set LLSV, LOSV, HISV and HHSV
if you want those values made available to BOY.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: CSS BOY Meter widget limits Paweł Prędki
Re: CSS BOY Meter widget limits Kasemir, Kay
Prev: RE: CSS BOY Meter widget limits Mark Rivers
Next: Re: CSS BOY Meter widget limits Paweł Prędki
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
