W dniu 2011-01-25 16:55, Andrew Johnson pisze:
Hi Paweł,
On Tuesday 25 January 2011 09:17:08 Paweł Prędki wrote:
The thing is the HIHI, HIGH, LOW and LOLO values are initialized in the
record but BOY doesn't seem to be loading them. The record I'm referring
to is as follows:
record(ao,DISK:FORWARDING") {
field(DESC,"Forwarding Throughput")
field(DTYP,"Raw Soft Channel")
field(EGU,"Gbps")
field(OMSL,"supervisory")
field(DRVL,0.0)
field(DRVH,10.0)
field(LOPR,0.0)
field(HOPR,10.0)
field(HIHI,8.0)
field(HIGH,7.0);
field(LOW, 1.0);
field(LOLO,0.0)
The IOC also checks that you have something other than NO_ALARM in the
relevant xxSV field before it will provide the limit through CA, otherwise it
would have no way to tell whether your LOLO limit is an alarm limit or just
the default value for the LOLO field. You must set LLSV, LOSV, HISV and HHSV
if you want those values made available to BOY.
- Andrew
Hi Andrew,
That solved it! Thanks a lot for all the replies!
Pawel
- Re: CSS BOY Meter widget limits Kasemir, Kay
- Re: CSS BOY Meter widget limits Paweł Prędki
- Re: CSS BOY Meter widget limits Andrew Johnson
Re: bo Record not forcing VAL to 0 or 1 Andrew Johnson
<2011>
2025
2026
Py-Epics and string waveform records Craig.Haskins
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
