1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: GigE driver for Area Detector
To: <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Thu, 27 Jan 2011 08:51:56 +0000
Could you attach the complete list of errors at startup please? The ones
that I see so far are because the camera doesn't support the same
feature set as the prosilica. From your XML file, the following are
supported:
Gain
Gain Mode
Exposure
White Balance (manual mode may not work properly as the camera also
allows setting of the green channel)
All the standard areaDetector parameters supported by aravis
The following won't work:
Iris
Exposure algorithm
Any "Auto target" values
If you copy aravisProsilica.template to aravisBasler.template and remove
the offending records then it won't print the messages. It looks like
aravis can talk to your camera, just not some of the features.
Tom Cobb,
Diamond Light Source Ltd.
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire
OX11 0DE
Tel +44 (0) 1235 778582
> -----Original Message-----
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: 27 January 2011 01:26
> To: Cobb, Tom (DLSLtd,RAL,DIA); [email protected]; Rees, Nick
> (DLSLtd,RAL,DIA)
> I have kludged a st.cmd file and when I run example with my st.cmd the
camera
> is found.  However, then I get many messages which I interpret as
error
> messages.  Here are some of them:
> # aravisCameraConfig(portName, cameraName, maxBuffers, maxMemory)
> #aravisCameraConfig("CAM1", "Prosilica-02-2166A-06844", 50, -1)
> aravisCameraConfig("CAM1", "Basler-20913924", 50, -1)
> Looking for camera 'Basler-20913924'... Found 0x8f23500
> # NDStdArraysConfigure(portName, queueSize, blockingCallbacks,
NDArrayPort,
> NDArrayAddr, maxMemory)
> NDStdArraysConfigure("ARR1", 2, 0, "CAM1", 0, -1)
> # Final ioc initialisation
> cd
"/afs/slac/g/testfac/workspace/zms/rhel5/R3.14.11/ioc/aravisnew/aravisGi
gE-
> 0-1-2/iocs/example"
> dbLoadRecords 'db/example_expanded.db'
> iocInit
> Starting iocInit
> ## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
> ## EPICS Base built Dec 10 2010
> 2011/01/26 17:18:55.725 asynPortDriver:drvUserCreate: addr=0, cannot
find
> parameter ARAVIS_EXPAUTOTARGET
> ARAVISCAM1:CAM:ExpAutoTarget_RBV devAsynInt32::initCommon
drvUserCreate
find
> parameter ARAVIS_GAINAUTOTARGET
> ARAVISCAM1:CAM:GainAutoTarget_RBV devAsynInt32::initCommon
drvUserCreate
find
> parameter ARAVIS_IRISAUTOTARGET
> ARAVISCAM1:CAM:IrisAutoTarget_RBV devAsynInt32::initCommon
drvUserCreate
find
> parameter ARAVIS_IRISVIDEOLEVELMAX
> ARAVISCAM1:CAM:IrisVideoLevelMax_RBV devAsynInt32::initCommon
drvUserCreate
find
> parameter ARAVIS_IRISVIDEOLEVELMIN
> ARAVISCAM1:CAM:IrisVideoLevelMin_RBV devAsynInt32::initCommon
drvUserCreate
find
> ARAVISCAM1:CAM:IrisVideoLevel_RBV devAsynInt32::initCommon
drvUserCreate
> 2011/01/26 17:18:55.726 asynPortDriver:drvUserCreate: addr=0, cannot
find
> ARAVISCAM1:CAM:ExpAutoTarget devAsynInt32::initCommon drvUserCreate
find
> ARAVISCAM1:CAM:GainAutoTarget devAsynInt32::initCommon drvUserCreate
find
> ARAVISCAM1:CAM:IrisAutoTarget devAsynInt32::initCommon drvUserCreate
find
> parameter ARAVIS_EXPAUTOALG
> Is it fair to say that aravis as it now is, can't communicate with the
camera?
> I have attached an xml dump from the camera.
> Thanks,
> Zen
> > From: [email protected] [mailto: [email protected]]
> > Sent: Wednesday, January 26, 2011 12:45 PM
> > To: [email protected]; Szalata, Zenon M.;
[email protected];
> > [email protected]
> > Mark is right. We pass the .cmd file through MSI to generate the
boot
> > file. The rule is:
> > %.boot: ../%.cmd
> >         $(MSI) $(SYS_BOOT_FLAGS) $(USR_BOOT_FLAGS) $< > $@
> > This is so we can have identical startup scripts for different
> > architectures.
> > However, in this one off case, it should be easy enough to edit the
.cmd
> > file and manually substitute the macros.
> > Cheers
> > Nick Rees
> > Principal Software Engineer           Phone: +44 (0)1235-778430
> > Diamond Light Source                  Fax:   +44 (0)1235-446713
> > > From: [email protected] [mailto:tech-talk-
> > > [email protected]] On Behalf Of Mark Rivers
> > > Sent: 26 January 2011 19:35
> > > To: Szalata, Zenon M.; Cobb, Tom (DLSLtd,RAL,DIA); tech-
> > > [email protected]
> > > I think they generate their startup files from a script.  You
probably
> > > need to manually create an st.cmd file based on their template.
> > > [mailto:[email protected]] On Behalf Of Szalata, Zenon
M.
> > > Sent: Wednesday, January 26, 2011 1:33 PM
> > > To: [email protected]; [email protected]
> > > Hi Tom,
> > > I downloaded the tar file from the link below.
> > > I am having trouble building the examples.  I get this error:
> > > make[4]: Entering directory
`/afs/slac.stanford.edu/g/testfac/vol4/workspace/zms/rhel5/R3.14.11/ioc
aravisnew/aravisGigE-0-1-2/iocs/example/iocBoot/iocexample/O.linux-x86'
> > > Installing created file ../../../bin/linux-x86/../stexample.sh
> > > make[4]: *** No rule to make target
> > > `../../../bin/linux-x86/stexample.boot', needed by `buildInstall'.
> > > Stop.
> > > I can't find stexample.boot file.  Is it perchance stexample.src?
> > > Anyway, the file tree structure you are using is different from
what I
> > > am used to and right now I feel a bit at a loss.
> > > Thank you,
> > > Zen
> > > > From: [email protected] [mailto:[email protected]]
> > > > Sent: Monday, January 17, 2011 9:53 AM
> > > > Cc: [email protected]; Szalata, Zenon M.
> > > > Subject: GigE driver for Area Detector
> > > > Hi all,
> > > > As a couple of people have asked for it, I've made a preliminary
> > > release
> > > > of the my areaDetector driver for GigE cameras on Linux based on
the
> > > > aravis library. It is only tested on Prosilica/AVT cameras,
although
> > > it
> > > > should work with all GigE vision compliant cameras but, as
always,
> > > some
> > > > cameras are more compliant than others...
> > > > http://controls.diamond.ac.uk/downloads/support/aravisGigE
> > > > Once you have built the module, there are 2 helper programs in
the
> > > > bin/linux-x86 directory, arv-show-devices will list all the GigE
> > > vision
> > > > cameras visible on the network, and dumpXml will dump their
Genicam
> > > xml
> > > > files to disk. Please email me the outputs of these 2 programs
if
> > > your
> > > > camera doesn't work properly.
> > > > Thanks,
> > > > Tom Cobb,
> > > > Diamond House
> > > > Didcot
> > > > Oxfordshire
> > > > OX11 0DE
> > > > This e-mail and any attachments may contain confidential,
copyright
> > > and or
> > > > privileged material, and are for the use of the intended
addressee
> > > only. If you
> > > > are not the intended addressee or an authorised recipient of the
> > > addressee
> > > > please notify us of receipt by returning the e-mail and do not
use,
> > > copy, retain,
> > > > distribute or disclose the information in or attached to the
e-mail.
> > > > Any opinions expressed within this e-mail are those of the
> > individual
> > > and not
> > > > necessarily of Diamond Light Source Ltd.
> > > > Diamond Light Source Ltd. cannot guarantee that this e-mail or
any
> > > > are free from viruses and we cannot accept liability for any
damage
> > > which you
> > > > may sustain as a result of software viruses which may be
transmitted
> > > in or with
> > > > the message.
> > > > Diamond Light Source Limited (company no. 4375679). Registered
in
> > > England
> > > > and Wales with its registered office at Diamond House, Harwell
> > > Science
> > > and
> > > > Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> > This e-mail and any attachments may contain confidential, copyright
and or
> > privileged material, and are for the use of the intended addressee
only. If
> you
addressee
> > please notify us of receipt by returning the e-mail and do not use,
copy,
> retain,
> > distribute or disclose the information in or attached to the e-mail.
individual and
> not
> > Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> > are free from viruses and we cannot accept liability for any damage
which
> you
> > may sustain as a result of software viruses which may be transmitted
in or
> with
> > the message.
> > Diamond Light Source Limited (company no. 4375679). Registered in
England
Science and
RE: GigE driver for Area Detector Szalata, Zenon M.
GigE driver for Area Detector tom.cobb
RE: GigE driver for Area Detector Mark Rivers
RE: GigE driver for Area Detector nick.rees
Prev: Re: Py-Epics and string waveform records Matt Newville
Next: RE: GigE driver for Area Detector Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: GigE driver for Area Detector Szalata, Zenon M.
