Hello Jay,
On Thursday 27 January 2011 18:33:29 Jay Steele wrote:
> However, the following does
> not work with MEDM. I just get a flash of a DOS window.
> command[0] {
> label="dxp-flyscan"
> name="xterm"
> args="-e "dxpflyscan.sh /cygdrive/c/epics/bash/mca1.txt""
I suspect the problem is your use of the double-quote characters in your
arguments. MEDM should probably be escaping them, but since it doesn't you
might want to try using single quotes instead.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- problem running bash script with MEDM on Windows/Cygwin Jay Steele
Re: problem running bash script with MEDM on Windows/Cygwin Tim Mooney
Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
<2011>
2025
2026
registrySetTableSize() unusable Till Straumann
<2011>
2025
2026
