1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: problem running bash script with MEDM on Windows/Cygwin
Cc: Claus Flachenecker <[email protected]>
Date: Thu, 27 Jan 2011 16:33:29 -0800
Hi EPICS community,
      I’m running EPICS 3.14.11 on Windows XP and using windows extensions 32 MEDM as the GUI. I’m trying to run bash scripts from MEDM. I’m able to launch a xterm from a button created using MEDM’s shell command palette. The xterm window runs cygwin and I’m trying to use an argument to xterm to run the bash script. My problem is that the command line arguments are not parsed correctly when I specify two command-line arguments for xterm. I can run the following from a windows DOS window: xterm –e “dxpflyscan.sh /cygdrive/c/epics/bash/mca1.txt”. This works to create the cygwin xterm window and launches the dxpflyscan.sh script with /cygdrive/c/epics/bash/mca1.txt as an argument. However, the following does not work with MEDM. I just get a flash of a DOS window.
“shell command” {
                object {
                                x=70
                                y=167
                                width=127
                                height=42
                command[0]{
                                label=”dxp-flyscan”
                                name=”xterm”
                                args=”-e “dxpflyscan.sh /cygdrive/c/epics/bash/mca1.txt””
    Has anybody had better success at getting bash scripts to work with MEDM on windows/cygwin? MEDM does work when I only specify the shell script name as an argument to xterm.
Cheers,
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
Re: problem running bash script with MEDM on Windows/Cygwin Tim Mooney
Re: problem running bash script with MEDM on Windows/Cygwin Andrew Johnson
Prev: Re: Py-Epics and string waveform records Matt Newville
Next: registrySetTableSize() unusable Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OMS VS4 "omsPut: card 0 send ring full!" Nerses Gevorgyan
Next: Re: problem running bash script with MEDM on Windows/Cygwin Tim Mooney
