1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OMS VS4 "omsPut: card 0 send ring full!"
To: Ron Sluiter <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jan 2011 11:20:12 -0500
That was due to wrong interrupt configuration.
Thanks a lot,
Nerses
On 01/27/2011 01:44 PM, Ron Sluiter wrote:
Hello Nerses,
If the drvOms driver is configured to use VMEbus interrupts
(i.e., omsSetup() interrupt vector argument is nonzero), then
the driver puts messages going to the controller into an EPICS ring
buffer and enables the controller's transmit IRQ.
One guess (I have never seen this error message before, so
this guess is in the category of 'wild') is that the omsSetup()
interrupt level argument does not match the jumper on the
board.
Another guess, if you are upgrading from a very old version of
the motor record to a recent version, could be this (from the
"Motor Record: Known problems with Release 5-9"
An undocumented change was made in R5-4 to two OMS setup functions. Namely, the unused 2nd argument ("axes per card") was eliminated from omsSetup() and oms58Setup().
If I missed on both the above guesses, let me know.
Ron
On 1/27/2011 11:22 AM, Nerses Gevorgyan wrote:
Does anyone have a clue why I'm getting this error?
In my setup I've MVME 2300 on VxWorks 5.5 with EPICS R3.14.12.
Motor controller card is OMS VS4.
Any help would be appreciated.
Nerses
OMS VS4 "omsPut: card 0 send ring full!" Nerses Gevorgyan
Re: OMS VS4 "omsPut: card 0 send ring full!" Ron Sluiter
Prev: RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
Next: Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: OMS VS4 "omsPut: card 0 send ring full!" Ron Sluiter
Next: problem running bash script with MEDM on Windows/Cygwin Jay Steele
