1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ca_create_channel memory management
To: [email protected]
Date: Fri, 28 Jan 2011 09:10:29 -0800 (PST)
If you allocate memory and send a pointer to it in the puser field of
ca_create_channel, does it get freed when ca_clear_channel is called, or
should I do that explicitly?
Thank you for your time,
Patrick
Re: ca_create_channel memory management Andrew Johnson
Prev: Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Next: Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ca_create_channel memory management Andrew Johnson
