1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_create_channel memory management
To: [email protected]
Date: Fri, 28 Jan 2011 11:31:43 -0600
Hi Patrick,
On Friday 28 January 2011 11:10:29 [email protected] wrote:
> If you allocate memory and send a pointer to it in the puser field of
> ca_create_channel, does it get freed when ca_clear_channel is called, or
> should I do that explicitly?
There's no way the CA API could know whether it should do that or not, so it
doesn't and it falls on you to do it yourself.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: ca_create_channel memory management pthomas
Prev: Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
Next: RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ca_create_channel memory management pthomas
Next: Re: ca_create_channel memory management pthomas
