1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsMessageQueue Linux PREEMPT_RT
To: [email protected]
Date: Fri, 28 Jan 2011 12:28:42 -0600
On 01/28/2011 10:37 AM, Eric Norum wrote:
Hmm...
I see that my name is on the code in osi/os/default/osdMessageQueue.cpp
but I don't think that I actually wrote it. I would have expected that
all allocation would be done at message queue initialization -- I agree
that allocating at run-time is a poor idea.
Sure but pre-allocation of the 'event nodes' is not possible since.
There is one such node per thread that is blocking on the queue.
Unless you know how many threads may block you can't pre-allocate.
However, I'm not sure these 'event nodes' are really necessary.
They are only used to notify blocked threads in a FIFO manner.
One could have just two 'epicsEvent's (one for TX, one for RX)
and let all receivers simply block on the single RX 'epicsEvent'.
The 'epicsEvent' itself should ensure that just one thread
wakes up. However, it may be that the wake-up is not strictly
FIFO but governed by whatever policy 'epicsEvent' uses.
- Till
On Jan 28, 2011, at 8:16 AM, <[email protected]
<mailto:[email protected]>> wrote:
Hi Andrew
The PREEMPT_RT patch makes the kernel fully pre-emptive (leading to
improved maximum latency) and adds support for priority inheritance
mutexes. There are no user space API changes, the code to use
_POSIX_THREAD_PRIORITY_SCHEDULING and _POSIX_THREAD_PRIO_INHERIT is
already in libCom (if disabled by default). I'd like to use the
epicsMessageQueue from a high priority thread but the send and receive
functions may calloc an eventNode, and that might cause a page fault or
block my thread on the malloc lock. I'd like to be able to pre-allocate
the eventNodes because I know the maximum number of threads that may
wait on the queue in advance.
James
Eric Norum
[email protected] <mailto:[email protected]>
epicsMessageQueue Linux PREEMPT_RT james.rowland
Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Prev: Re: ca_create_channel memory management pthomas
Next: Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Next: Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
