Caveat -- the RTEMS code also does a lazy allocation but only if a Receive method/function is invoked with a size smaller than the maximum message size used to create the queue.
On Jan 28, 2011, at 10:22 AM, Till Straumann wrote:
> Yes. But that's a hack (the user must know some implementation details of message queues). IMHO the default implementation (RTEMS and
> probably vxWorks are OK) could be improved.
>> We probably should add a routine to the API to allow the eventFreeList to be
>> pre-allocated, but you probably want to be able to run on existing versions of
>> Base.
> I'd consider such a routine a bit 'hackish'. I'd vote for improving the implementation. Of course, that would not be retroactive and your
> recommendation above could be used as a work-around on older versions.
> - Till
>> Eric — unless you stole the code from someone else you were the author of all
>> the *MessageQueue.* files, 'bzr log' does not lie...
>> - Andrew
>From the indenting style I infer that Marty Kraimer wrote the code and had me commit it......
Does that count as stealing??? :-)
Eric Norum
[email protected]
- Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
- epicsMessageQueue Linux PREEMPT_RT james.rowland
- RE: epicsMessageQueue Linux PREEMPT_RT james.rowland
- Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
Re: ca_create_channel memory management Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
