1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsMessageQueue Linux PREEMPT_RT
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jan 2011 15:34:32 -0600
On Friday 28 January 2011 12:30:59 Eric Norum wrote:
> From the indenting style I infer that Marty Kraimer wrote the code and had
> me commit it......
Marty *never* uses GNU-style function definitions (putting the routine name at
the beginning of a new line after the return type and any decorations), so I
still think this had to be your code.  He might have written the vxWorks
implementation, but I doubt that you would have listed yourself as the Author
if that was the case.
The vxWorks implementation doesn't appear to need anything like an eventNode,
and I'm wondering if the free-list is even necessary — couldn't the eventNode
just be allocated on the stack of the thread that's waiting?  Every call to
getEventNode() is followed after the epicsEventWait*() by a line that puts it
back on the eventFreeList.  I guess the important question is how much work it
would be to create a new epicsEventId every time.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
epicsMessageQueue Linux PREEMPT_RT james.rowland
Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Prev: ca_create_subscription element count pthomas
Next: Re: Setting BPTR Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsMessageQueue Linux PREEMPT_RT Eric Norum
Next: Re: epicsMessageQueue Linux PREEMPT_RT Till Straumann
