Hi Till,
On Friday 28 January 2011 15:04:10 Till Straumann wrote:
> I see that the problem for aao/aai was fixed in
> 3.14.12 but it would be nice to be able to set
> BPTR for waveforms, too.
I don't see any obvious backwards-compatible way to allow that.
I just compared the (3.14.12) aai and waveform records, and I don't really see
much difference between them, other than allowing device support to set BPTR
and the BUSY field (which I don't think anyone uses any more); couldn't you
just convert your waveform device supports to aai/aao instead?
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Setting BPTR Till Straumann
Re: epicsMessageQueue Linux PREEMPT_RT Andrew Johnson
Re: ca_create_channel memory management pthomas
<2011>
2025
2026
ca_create_subscription element count pthomas
<2011>
2025
2026
